- Gracias recibidas: 1
- Foro
- Mecánica en español
- ¿RAV4 2001,2002,2003,2004 CON INMOBILIZADOR?
- HUANCASIP
- JUANRA78
- Expert Boarder
- Gracias recibidas: 7
- maniatiko405
le volvi a darle partida y volvio a pararse pero ahora es como que el ralenti esta bajo cae mucho el ralenti me dijeron que limpiara el flujometo sera posible que con eso ya estara lista la camioneta.
- HUANCASIP
Passlock
Your vehicle is equipped with the passlock
Theft-deterrent system.
Passlock is a passive theft-deterrent system. Passlock enables fuel if the ignition lock cylinder is turned with a valid key. If a correct key is not used or the ignition lock cylinder is tampered with, fuel is disabled.
During normal operation, the SECURITY light will go off approximately five seconds after the key is turned to the RUN ignition position.
If the engine stalls and the SECURITY light flashes, wait about 10 minutes until the light stops flashing before trying to restart the engine. Remember to release the key from the START as soon as the engine starts.
If the engine does not start after three (3) tries, the vehicle needs servise.
If the engine is running and the SECURITY light comes on, you will be able to restart the engine if you turn the engine off. However, you passlocksystem is not working properly and must be serviced by your dealer. Your vehicle is not protected by passlock at this time.You may also want to check the fuse (see “ Fuses and Circuit Breakers” in the Index). See your dealer for service.
A por cierto corrijanme si este tema no es de aqui por ser de isuzu o diganme como abrir otro post gracias
- duran.
Agradezco su soporte. Feliz tarde
